Tip for removing dents
On Saturday night, had a few regulars out in fancy dress, one decided to sit on the bonnet for a photo.
Result on looking at the bonnet in daylight a big dent of a bum.
Lifted the bonnet to see if I could push it back out but dent in area that is not accessible even removing under bonnet trim, thought of how much this is going to cost, as it was on the high crease line in the centre and both sides of the crease where down.
Thought about it for a while, then the phone rang, then the idea suddenly transpired.
took phone out of cradle, I have one of those lick and stick down ones on a long spring, that sticks down to the base that comes with it in the top tray.
Got out and gave it a good lick and placed it in the centre of the dent pushed the lock on the suction cup and pulled gently result no more dent. :whew:
Glad you're sorted. On a larger area and a 'soft' compression often the suction pads will do the trick. So you've been lucky in that regard.
