GEARBOX OIL..?
what type/grade/spec gearbox oil do i need for the 1.9tdi 130pd awx.?
would i be correct in thinking a GL4 gear oil.?
i plan on changing it tomorrow so something hopefully from halfrauds will do.?
I've changed my gearbox oil today , I put 2 litres of Fuchs TITAN SINTOFLUID SAE75W-80. I had the oil from opie oils its a nice pale yellow ,not like the dark brown oil that came out. The gearchange is a little improved. Before , it used to stick in gear,sometimes wouldn't go in gear at traffic lights . It still does this but not so often.
Edited by flabio
I've changed my gearbox oil today , I put 2 litres of Fuchs TITAN SINTOFLUID SAE75W-80. I had the oil from opie oils its a nice pale yellow ,not like the dark brown oil that came out. The gearchange is much improved as before , it used to stick in gear,sometimes wouldn't go in gear at traffic lights .
thanks, i have a look at that. but ive been under the impression that the oil grade should be 75w-90.
I used this stuff off avaiable off ebay FEBI SAE 75 GL-4 21829.
I did both mine and my dads and inparticular it made my dads car so much quieter it was well shocking. Both came out dark brown.
Best to contact your dealer and ask them.
The stuff I got was G 060 stuff. £5 odd per litre +vat per litre.
Might vary with your box but pretty sure all the 6 speed boxes use the same stuff.
Phil
how much oil does the 5 speed box take.? ive opted for febi.
it holds 2 and a quarter litres , but only 2 litres comes out .
http://www.ebay.co.u...1#ht_1054wt_906
Edited by flabio
