VCDS Log - Fault fuel pump!
Can someone help understand what is the below problme. I do see that the fuel niddle does goes down to zero and after sometime, returnes back to normal:
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 803 M HW: 1Z0 920 803 M
Component: KOMBI H05 0405
Serial number: 00000000000000
Coding: 410800
Shop #: WSC 73430 031 00999
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 3E5DEB00A16C949
1 Fault Found:
9453074 - Fuel Level Sensor 1
B103E 1B [008] - Resistance Too High
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 32
Reset counter: 190
Other error is:
Address 01: Engine (J623-CLCA) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 EJ HW: 03L 906 018 BR
Component: R4 2,0L EDC H22 7020
Revision: 42H22--- Serial number:
Coding: 00110012040500080000
Shop #: WSC 33361 790 00999
ASAM Dataset: EV_ECM20TDI01103L906018EJ 003003
ROD: EV_ECM20TDI01103L906018EJ.rod
VCID: 76CD3320C9DC1C9
1 Fault Found:
4713 - No Communication with ABS Brake Control Module
U0121 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0 0 0 0 0
There's no problem with the fuel pump. Either the sender for the fuel gauge display is faulty or there is a bad connection. The sender clips into the fuel delivery unit and is available as a seperate part.
Isn't this car still under warranty?
It is under warranty. I left my car for 5 day with the service station and they are clueless. They are waiting for inputs from Skoda Auto India and their response is disappointing.
