Multiple issues
Hello
The car is 2007 Superb 2.5TDI 120kw automatic. 118 000km.
120 000km full maintenance is done week ago.
Following problems were already present before that.
1.
Very annoying noises come out of centre console are or particulary from this area where radio and ashtray are.
is there any instructions (writeup with pics?) around to open it up and check bad joints or loose parts?
2.
When i turn right bad noise comes from right front.
3.
In lower gears (2-3) on acceleration engine suddenly becomes very loud and i feel kind of power loss (injectors? air intake?). In higher speeds on highway all fine.
Any ideas or suggestions?
Best regards
tiffest
Hm I'm not sure, but for 2 it can be cv joint?!
About 2 years ago I saw youtube clip about strange noise from PASSAT dashboard...it is really unimportant and very familiar wit all VAG cars.
I think for that you dont have worry, just get used to it.
Once again sorry for bad english.
I hope so that rotodiesel and other members from this forum will read and replay on this topic.
Sorry, but with this info I can just say that your car is broken. Nothing else really.
You have to be more specific. For number
1. what kind of noise is it? Clunking, creaking, rubbing or something else?
2. again, what does it sound like? If clunking, then it could be bad ball joint for tie rod end or control arms. If you drive and turn right and you got a repeative clunking, when turning right, it could be bad cv joint.
3. search for vag-com specialist from your area and let him check for codes. Also let him check, how to engine works, while driving around (driving around, with cable and computer diagnosing engine).
Has it been in a accident?
If you are not sure check all the shut lines (body panels) from the front to the rear doors, including around the headlamps and front grille. They should all be very even if not suspect a crash repair.
Its kind of creaking noise. Feels like two panels rubbing against each other.
Seems that I still should find some local man and drive around.
Thanks anyway.
