Rocker/Cam cover help
Prob a daft question....... Are all octavia vrs rocker covers the same ?
Looking into getting one so i can have it powder coated
Any info or advice would be appreciated
Edited by Lloyd55vrs
Yes, haven't seen a different one
Sent from my Galaxy S2 not a Crapple!
Found some on ebay but also they are the BAM engines
? Some of the 1.8t ones listed look abit different :(
Hmmm
I also hear about bolt down or push coil packs :(
all are the same,even the ones from Audi (longitudinal engines) fit
Cool :)
not all the same Lloyd
Mine is clean and polished, yours is dull... :rofl:
so they are different.....
P.S yep all the same buddy..................go for it.
you show off! :$$$:
you show off! :$$$:
:rofl:
Some are green :happy: (go on Gee..... you know you want to post a pic.... i can't be a**** )
Steeeeeve :) i want that but red lol
Prob not brave enough but...... How easy do they come off ?
Remember only powdercoat the external part :)
Not the underside :)
Cheers mate..... I have my eye on someone thats done at least a couple now ;) so fingers crossed said person can sort me out :)
very hard...must be a surgeon at least... :rofl:
Is very easy to remove,screws out and that's it!May get sticky so use some force .
Very important...with the new seal you must put some sealant at the edges,otherwise will leak out.
There are the spots
Edited by IulianE
Yep like this!! Notice the tape along all the sealing edges
And all the bolts in the holes to stop the thread filling with the coating
That looks very clean before powder coating :)
Do u sand blast something ?
Eeeeek ive dug up 2 kinds ??
This got like square platforms
This One has round hole jimmy doo da's
Would mine be the ones without the square bits
Second is a BAM will that be ok ? I dont want issues :(
If you're not sure,order one by engine code
But all are the same ,again!.Mine has square coils (old type) ,but the seal is round ,because all are the same.
this is the only type gasket ,because all are the same.
Edited by IulianE
Yours is the round hole one mate.
Cheers guys
And yeah steve mine is the round holes
So there will be no difference with the BAM except i will then have a inlet and rocker off the car ;)
Is there a part number on urs steve :)
They are both identical fit as mentioned so are both ok. If you want to keep same looking top as yours go for the round hole. The only reason as bam take the bolt down coil packs which will actually fit on the round hole one anyway
Aha :) all probs solved........ Good ol' clive has sorted me out :)
