Drivers rear door deadlocked?
I removed my door handles last night, fitted them all back together and tested them etc and they all worked fine.
Came out this morning and the drivers rear door won't open from the inside or out :S
Any ideas?
pull out the handle.
you will see the small plastic part at the end of the bowden cable
get a small flatheaded screwdriver and gentle lever that down a few notches.
they need to go back into the exact notch to work properly, by the sounds of it you have put it too tight and it is not going back far enough to release the lock mechanism
if this does not work give me a pm as i no what else could go wrong!
