oily pipe above the air filter
hi i have an oily pipe above the air filter. it is quite oily and even goes into the Throttle body pipe connector
is this a) a problem and b ) if it is, is it easy to fix
Edited by deano266
bump
Just in case it matters, what is your engine code, ie A?? or B?? ?
Alll the pipes should be hidden under the air filter box thing, I think.
The Engine code is AUB
