loss of power ?
hi all again i have a new problem this time lol
i have a 51 plate octavia vrs which has just had a new turbo fitted and was running fine but last night i took her out for a spin she pulled fine all the way to 6 and a half in first but when i changed to 2nd she would only go to 5000 and would start to pop and fart and stutter up the rav range slowly the same in 3rd but came in alittle earlier at 4 the same in 4th and 5th now then we fittered the new turbo she has a full service new plugs new coil packs new oil all new filters now i am at a loss because i am being told itcould be a number of things anyone got any ideas?
coil pack failing
failing already but they are all new
+1 for a coil pack on its way out. Mine did this before I got them changed under the recall. Did you gap the plugs etc before fitting? Also ince its starts playing does it idle around the 1000 rpm mark instead of 700 rpm like normal?
yep set the plugs and she sits nicly at 700 just dies at 5 but i am off to the parts place tomorrow for another coil
Genuine coils ??
Have you changed the MAF ??
ooh that cheeky maf, always causing problems
i disconected the maf and took it for a run and she still does the same
right i have changed the maf and the coils yet again and it still having the same problem
Time to get it checked with vcds.
Sent from my HTC Vision using Tapatalk 2
just got back from having her plugged in to the computer and no faults i am starting to think it fuel related and eather the pump or ragulator
Fuel filter is a popular problem
that was changed a week ago
Earth straps on the engine etc ok?
Were the plug gaps set when they were fitted?
all earths are fine and yep plugs were set and just ordered a 4 bar perssure regulater should be here friday so we will see
Ive got a spare standard fuel pressure reg if u wanted to try it to see if thats the issue. I see ur only in Coalville which aint a million miles away.
do you think that could be the problem i have wondered because last night itook her down the motorway and when she gets to high revs she backs off then goes then backs off then goes andkeeps doing that which makes me think fuel starvation and it gets worse the higher gear your in i may take you up on the offer if thats ok with you just i wouldnt be able to get over to you till tomorrow as i have managed to get hold of a fuel pump today which is being ripped out the other car as we speak lol
