LED lights for DRL
The part number was YET-P13WDL and the product seems to have been removed from the stock items................. :think:
Maybe there is new stock on it's way :)
Hmmm, just as I thought. :-( I'll drop them a message later on, thanks :-)
Still not listed on Superskoda site for Yeti ( Strange )
I emailed Superskoda a couple of weeks ago enquiring on the matter and asking if and when these would become available again, but have received no reply since then. Strange indeed...
Superskoda seems to operate like the Mary Celeste. I have also emailed them several times (not for LED DRLs though), and got no reply. Funny thing is that previously when emailing them, I usually got a reply almost immediately. I was a bit hesitant about ordering again from them, but have since done so with no problems - my recent purchase arrived yesterday.
No reply to the one I sent (and I'd forgot about it actually!) :-(
  • 5 weeks later...
Finally got round to get a skilled auto electrician to fit led bulbs ordered from SuperSkoda last year
What he found was if you put the ignition on with out starting car, a short while it shows up bulb error
But like he said most people start car up right away anyway, then every thing is fine
If a problem does occur later he said he will fit the supplied resistors.
He was taken up on the difference these lights make,
Note A Guy in Halfords told me they had led bulbs for sale with separate resistors,but have not had them in stock lately ,sorry did not ask bulb types
Interesting - might have to get some myself, now the resistor issue appears to have been resolved
  • 4 months later...
With a lot of work and hours of experiments in front of my new car i finally manage to make my YETI a unique candy white YETI!! How??
I put LED DRLs which are working in two scales!
1. The brightest scale works when i start the engine (56 leds!!!)
2. The second scale which is less bright (lets say 70% less from the first) works when i open the position lights( the small bulbs that are left and right from the big lights which i also made them with 13 led lights each(26 led as a whole)) and still working when i open my OEM Bi xenons with AFS!!
Really incredible result!
Now the only front lights that are not xenon or led are the fog lights and i am not intentinting to do them because they will not work as led lights in a foggy situation!
Congratulations. Could you upload some photos, please?
And also how you did it, what bulbs you used etc.
Maybe you should post a 'how to' in the technical section.
Here are the DRLs open with the led position lights only (the camera is without flash)
The same photo but more close from the one side! (56 leds in DRLS but 30% of their brightness and 26 leds in the position lights) photo without flash
Here are the DRLs open with the led position lights only (the camera is with flash)
The DRLs fully open when i start the engine. Can you see the difference in brightness from the previous picture?? they are 70% more bright (56 leds) (the photo was taken without flash)
The case for the papers in front of the codrivers seat with led light
The led lights inside the cabin...(the two on the back have been bought from superskoda, the two in front for the driver and co driver are 13 leds each)
All the lights open (Led DRLS 30% of the muximum, led position lights and Bi xenons OEM) photo without flash
All the lights open (photo with flash)
All the lights open, closer look (photo with flash)
Only DRLS open full bright (first scale) photo with flash
Photo with led in the boot
And the previous situation!!
I have also bought some things from superskoda and there all perfect... except the really powerful amortiser for the hood! 450Nm!!! I bought a 300 Nm from Greece and now works perfect!
I didnt post and with the fog lights on... can you imagine the light??? :giggle: :giggle:
Thank you for posting so many pictures. Are you getting any canbus error messages?
No can bus errors because of the Ohms i used in both lights positions and DRLs. I used Ohms so if a led turns off then will say it doesnt working!
The difficult part was to find the way for the wire from the DRLs to position lights... believe me its a snake like little hole! i used an aluminium wire to find the way... 30 minutes of trying... but if you are lucky maybe 5 minutes!!! or less!
No wire outside the cases of the bulbs, nothing can be seen when the hood is open! really proffesional work!
