Help, leaking sunroof, please help
1.9 tdi skoda superb 55 plate.
This morning, I had water leaking from the roof, all the seat was wet and a big puddle on the car, driver side.
Had to get to work, quickly cleaned up and drove to work.
I just checked and I pinched the tube, near the door hinge and water began to come gushing out.
However, not sure if it is cured, but how can I ensure that the water drain in the sunroof is clear, please help!
I've had good results previously with an air duster and net curtain wire/cord:
(This was clearing blocked roof drains on a CRX)
Gaz
Must of cleared it at dinner time. I put a jug of water through the sun roof and it came fusing out
My only concern about using curtain springy stuff is, if you are unlucky or a bit heavy handed, you could push the tube of its adaptor.
Absolutely - easy does it is a hard and fast rule. All too easy to get it wrong if the blockage is severe or bends are too tight to get around.
Gaz
