Interior lights not working - Octavia 2.0
My interior lights have stopped working on my Octavia 2006. I have looked at fuses but they seem fine I think.
What to do?
Is the ligh switched on?
ODIS Champion why do you have to be smart when you obviously are of no benefit in this forum. Your humor is of a low level. Can I suggest that you refrain from such replies. This forum is of a high standard and you should go elsewhere to entertain yourself!
Whoops
Have you checked the bulb?
If so, then you need to wait for user Tech1e to assist as he will know the answer...
What are you whispering for?
What to do?
Lol, as well as what tech1e suggested (which is a very very valid suggestion, coming from one of the most knowledgble sources on this forum) Check the fuses properly, then you will know if they are fine or not. Diagnostics by guesswork or omitting to check the simple things can lead to much embarressment, and it won't be anyone else's but yours.
