Fault Code P0236 - what is the problem?
I've recently had a few times where I've started the car and driven with no boost at all. If I stop and restart the car, the problem disappears.
Today it happened again at lunch time but this time the engine management light came on. The code stored is P0236 - Boost Sensor "A" Circuit performance/range
What is the most likely culprit?
Is this with VCDS or some simple OBD fault reader?
From a quick google it could be a problem with the MAP sensor.
MAP sensor in my opinion, not expensive part
that should do it
The probable causes for this code are:
  • intake/exhaust leak
  • hose connection(s)
  • MAP sensor
  • turbo boost pressure sensor
Hope this helps
SN
  • MAP sensor
Hope this helps
SN
Thanks for that.
As it has been on and off, its not an intake/exhaust leak or hose connection - definitely an electrical problem
map sensor
map sensor
indeed or wiring to map sensor
yup, mine had same code, i unplugged it and plugged it in numerous times to clean contacts and that worked.
