Fuel temp sensor prob 1.9 sdi
Hi all I'm fixing up my Skoda anyways plugged in a scanner to the ODB port and scanned for codes there is only one and it says
Fuel temp sensor open or short to +
anyone got any ideas and where is the fuel temp sensor ?
Oh just found fuel temp sensor in the Haynes but anyone got any ideas on its error above
Simple fix or big problem
Surely someone has a clue
The temp sensor is only a small thing, if I remember correctly from when I had the Passat, you can unclip it from the pipe and put another one in there.
I don't know the codes but I am sure Google can help, good luck
