Octavia 1 RS 1.8T 150 bhp fault codes
Briskodians,
I'm looking to pick up this car and the fault codes are like this. Apparently, car is running on a bad battery which needs immediate replacement. Upon vag com scan done by another knowledgable briskodian we have these fault codes. Ross-tech wiki remedies suggest TB cleaning & alignment and reasons for other codes indicate faulty battery/generator. I'm a bit worried about the fault code for the Lights because of this thread http://www.briskoda....er-part-number/
Owner says there is no flickering on the xenons and they are working perfectly
Chassis Type: 1U - Skoda Octavia I
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
VIN: Mileage: 46860km/29117miles
Address 01: Engine Labels: 06A-906-032-AUM.lbl
Part No: 06A 906 032 SG
Component: 1.8L R4/5VT G 0010
Coding: 11500
Shop #: WSC 73430
VCID: 75EF30404F517BB0023
TMBELH1U06A011743 SKZ7Z0F3660259
2 Faults Found:
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
19534 - Throttle Control
P3078 - 35-00 - Airflow at Idle too Low
Readiness: 0000 0000
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601
Component: 31 AIRBAG VW51 0009
Coding: 13105
Shop #: WSC 73430
VCID: DDBFC8E057A143F0EA3
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 29: Left Light Labels: 1U0-941-651-29.lbl
Part No: 1U0 941 651
Component: EVG GDL + AutoLWR 0002
Coding: 00005
Shop #: WSC 73430
VCID: F0E18154B033DE98515
1 Fault Found:
01346 - Wire to igniter Unit
16-10 - Signal Outside Specifications - Intermittent
Address 39: Right Light Labels: 1U0-941-651-39.lbl
Coding: 00005
Shop #: WSC 73430
1 Fault Found:
01533 - Terminal 56 (High Beams)
32-00 - Resistance too High
Edited by mechophile
You're not really going to know what are persistent fault code until you replace the battery, clear the codes and see if they reappear after powering off/on the car.
ps
If there's enough battery to start the car, there should be enough juice to clear fault codes and do a re-scan.
ps :If there's enough battery to start the car, there should be enough juice to clear fault codes and do a re-scan.
I don't have first hand experience with vag-com. Ideally i know there should be no errors but in reality is it true that cars will have errors without owner realizing that something is wrong ? I mean everything is working good from driving perspective and there could be errors. By your PS remark, do you suggest that upon clearing and re-scan , all the errors should disappear. If so, how would we know that battery is weak. Even ross-tech wiki shows bad battery/generator as the reason for the errors for some of them. Will do a scan upon a new battery anyway. just want to learn
In the first instance, all those codes you have listed mean; at some stage when the car was running or starting, it ran out of enough amps to power the electrics
Error codes are generated when an error occurs, and sit there until cleared, whether the problem that caused the error has been fixed or not.
Therefore clearing the fault codes, re-starting and running the car, then re-checking for fault codes is the only way to see if you have persistent codes being generated.
The way to for a faulty battery and/or generator (alternator), is with a voltmeter
If the battery ever died or needed jump starting after sitting it would bring these codes up. If used the battery could be fine and hold charge.. I would clear them and see how the battery goes
rs 150bhp???? eh?
rs 150bhp???? eh?
yeah, sadly. It's de tuned in india to suit the fuel quality
