8581 fault code help
Anyone help with a fault code
VRS pd170 dpf removed and shark remap
new injectors following vosa recall
110,000 miles
Car intermittently losing power for a few seconds over last couple of days
Did same this morning, but brought coil and EM lights on
RAC patrol came out, erased codes, car runs fine now
Codes found were:-
00309 fuel pump
00802 air con (?)
P0135/PO322 ( crank sensor )
and 8581 which he doesnt have a reference for
Anyone help as to what 8581 is?
I would say the crank sensor might be the key one, could possibly cause the other faults?
yes was thinking that. last time the crank sensor came up it was a wiring fault not the sensor. thanks for reply
You have a mix of ODBII and VAG errors
000802 - Engine Speed Sensor (G28) - PO322 is the same thing - not the same as camshaft sensor
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P0135 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
My guess is that some of the codes are wrong :(
Yeah my money is on the crank sensor too. I had cold starting issues with mine PD170 vRS after the VOSA injector recall and the dealer was quick to point suspicion at the crank sensor.
Sorry, can't help with 8581 I'm afraid...
My advice is to have it scanned again before you spend any money on it, thats if you intend to fix it yourself as 8581 doesnt carry any reference so its possible their has been a mis-understanding somewhere along the line.
Sent from my LT26i using Tapatalk 2
thanks all. It has been in with these codes before, about 3 months ago, and was found to be a wiring fault- so will get to main dealer asap
many thanks
Main dealer couldnt fine a fault after repeated road testing
However, when I drove the car back, after about 10 mins it was as bad as ever. Stalling, rev counter needle behaving erratically, and a clicking relay noise from the ignition switch area. Almost as though an invisible hand was switching ignition on and off very fast.
Also noted my carphone was muted constantly ( it mutes for a few seconds when switching ignition on or off
I'm guessing a faulty ignition switch??
All sorted- 6 broken wires near oil cooler.
Last time was 3 broken wires near crank sensor.
Tech advises that he is seeing lots of vrs Octys with wiring faults
Still a lack of oomph low down- egr fault code showing. suggesting either to replace egr or get it mapped out band blanked off
