Disabling rear lights via VCDS when DRLs are on
Hi folks,
I'm trying to figure out how to disable the rear lights (running lights, license plate lights) when the light switch is set to position O (DRLs). Of course, brake light will light up when active.
I just received my VCDS HEX-USB+CAN cable from Ross-Tech this morning.
Hopefully some of you will know how to do this, it shouldn't be a biggie?
Thanks! :)
The following is from the Auto-Scan:
Saturday,06,October,2012,16:54:18:22496
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Chassis Type: 7N0
Scan: 01 03 08 09 10 15 16 17 18 19 22 25 2E 36 37 42 44 46 52 55
56 62 69 72 77
09-Cent. Elect. -- Status: OK 0000
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AE
Coding: 40000ABAE80508C040080080510011E4437000AE726DA5605C8540000040
Shop #: WSC 73430 790 00066
VCID: 387F95EA8B046BD8D95
Subsystem 1 - Part No: 1Z1 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 19041 26 0601
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 190411 05 54 0403
Coding: 0730ED
No fault code found.
This may be of some help to some. :)
Personally I'd leave them on (I have had mine turned on). As far as I am aware you can't enable / disable this feature with VCDS (a lot of people would like this). It can only be done with the dealer VAS tool. I am of course talking about a 2012 model but I presume yours is the same (only a tiny bit older)
On the older models it could be done but I don't think it can on ours.
