Upgrading the fan system in the fabia vrs
Has anyone done this?
I ask as this morning the windows took an age to clear, the fan makes LOADS of noise without alot of pressure comming out!
Any ideas?
Change your pollen filter, sounds blocked.
Air con clears the glass quicker. You can still have it on with the heater on except
on 'full windscreen' setting. Then it dehumidifies the car as it warms it up. :thumbup:
You may also have leaky doors I'm afraid.
Excessive condensation usually points toward either that, blocked and damp
pollen filter, blocked scuttle channels or broken washer pipe connections.
All easy to fix though.
Did not no that about the ac. whats the optinum setting for clearing the windscreen?
All the door have just recently been sealed, will rip out the pollen filter later and check scuttle channels aswell
I find having it on recirculate, AC on, temp at about 75% of full heat and
halfway between dash and screen venting. (About 2 oclock on the dial.)
Seems to clear mine and heat the car the fastest.
will try that cheers buddy
