Vrs charge pipe replacement ?
Had the motor on the ramp checkin over the decat pipe as I've got a rasp/whistle noise under boost the decats fine so started checkin the boost pipes over and the charge pipe isnt the best . The connection between the charge pipe and rubber pipe (spring clip) feels loose and I can move it around a fair bit :S it's got oil stains on it as well from where it looks like its been leaking.
Changing it doesn't look a big job but is there a better version to put on ? I've read somewhere the pipe off the agu engine uses jubilee clips instead and should be a straight fit .
Anyone know if this is right and has anyone changed theres before ?
Have a look on the creation Motorsport website. I think they do a replacement pipe but don't quote me on that :)
Just had a nose everythin they do I've already done lol
