Squeeky Seat Arrrrrr
Helo any one else had a problem with a squeeky seat? ive tryed everything i cant stop it making that horrible noise when i go over every single bump?
Drives seat ive tryed wd 40 ,oil but not done anything
Shane
My drivers seat clicks, if I break it clicks one way and if I accelerate hard it clicks the other way. nothing major but it's really annoying. Be interested to see what it could be, I've checked most things were tight etc...
There's a fix for this on uk-mkivs somewhere. I'll see if I can find it later.
snap
My MK1 did this it was the metal moulded bolt that the inside rear roller screws onto it started to flex and squeak, I took the seat out and tightend the roller up and snapped the bolt OOPS! I had to drill the rest out of the seat base and fit a suitable bolt with a nut to lock it to the base then screw the roller back on...squeak fixed! . Seat bases are hard to come by as most people want to sell you the set and skoda wanted a fortune can't remember if it was £180 or £280.
Sent from my LT26i using Tapatalk 2
Edited by 07 vRS Taxi
Thank you very much for all your replies :-) thanks tutorial would be grand thabks alot
