Passenger Airbag light trouble Code
I have now got a read on the Airbag problem;
"01228 E224 Airbag Cut Off Switch - Passenger Side - not a plausible signal"
With the Passenger Airbag turned on - the Airbag Light remains on in the Dash and the Airbag Off light flashes on the centre Console.
With the Passenger Airbag turned off - Airbag Light remains on in the Dash and the Airbag Off light remains on in the centre Console. (I would presume this is as it should be for this configuration)
Can anyone tell me exactly what I should check / do to resolve this issue. There are no other trouble codes of any kind showing on the Car and this code does not get cleared when you do a clear codes option.
does the code clear?
As I said above it does not clear when you do a "clear codes option". Thanks.
