Little light saying i'd blown a bulb...
This was a very helpful light which came on and did that really annoying BEEP!
My front right dipped beam headlight bulb went after 35000 miles, oh well.
Should I go to a skoda garage and get one, or can I get the same one from any halfords, and are they easy to replace?
Cant imagine they are...
Alex
It isnt that hard to replace, H7s I believe, and yes you can get it from Halfords.
If you are going to replace one, get a pair of uprated bulbs, you'll never look back :)
Instructions are in the manual but in the non-Xenon version the cover basically comes off the back (clips I think) and then the usual clip-over thing will be under that.
Assuming you can get your fingers around it (which was tricky with the Xenons, thus my comment) you can do it yourself no problem.
Which ones are the uprated ones, and can i get those from halfords aswell?
I assume the H7's are the standard ones, also any idea on price?
They sell 100 watt H7's about
Get some Osram Silverstars from www.powerbulbs.com :D They're easy enough to change, although the battery-side one is a bit of a pig to get to. :rolleyes:
Chris
cheers, gonna get them, 25 quids a bit steep, no?
Alex
I've never had to change a blown Osram bulb ;) Oh, and while you're there get some 100W Philips Rallye bulbs too for the main beam - transforms night time driving :D
Chris
will do. :thumbup:
I've got PIAA Extreme white plus bulbs on dipped headlights. Oh and what a difference they are to the standard. These are crystal white and from different angles you get a blue tinge. Looks great and much improved vision and fully e-marked. Should be for
