Help needed a noise has just started.
I origanaly thought it was a clutch problem. Then a brake issue but both work perfectly and it only happens when you turn a corner when i slow down change gear and release the clutch there is a scrapin noise like plastic but it also does it when i brake to go round a corner same scrapin noise and same again when i go over a bump sorry for the vague discription but any suggestions to look at or check would be much apreciated. Cheers bob
Plastic scraping noise when going around a corner????
Defo front then something hitting the wheel arch liner???.......
You might have the old style ARB with the plasctic lugs which break off and then the ARB slides .......could be this hitting the wheel arch liner??
