Fabia Dash
Hey All,
On the fabia the middle square in the dials can you make them light up and display the time and your miles etc?
yes, turn the lights on (round switch below and right of the steering wheel) HTH :D
If you mean where the warning lights are, then not as far as I know. Clock to the left, miles to the right.
:( Damm I used to like having it show in the middle ;)
If you have a maxidot display then it displays in the middle B)
How do I get that
You need to buy a maxidot cluster dash pod
then have it coded in to your cars electronics.
Not Cheap!! But if you really want the factory
sat nav as well then this is the first step as the satnav
works via the maxidot. Again, not cheap to do.
