check engine light while driving and now the car runs rough under 2000 rpm
Hi
I was out driving when suddenly the check engine came on, I drove the car for about 50 km to get home,
The car feels sluggish until I get over 2000 rpm then its pulling like normal
when i let the car idle it drops down to 700/800 rpm and the engine runs rough and makes the car vibrate a lot.
when I release the throttle at junctions and roundabouts, it feels like the car will stop
When the car idled rough and vibrated I disconnected the maf sensor and the car increased rpm to about 900 rpm and the enginge runs smooth
things I've checked and replaced
cleaned the Throttle position sensor
cleaned the maf and the connector
replaced the engine temp sensor
replaced plugs and coil
still behaves strangely
Please help me i cant afford to bring it to the stealership
engine is the 1,6 petrol bfq model
Get a Fault code checker on it. You can go through the list of things replaceing them not fixing it, Get it scanned it will give you a better idea of whats up.
First find someone with vag com and scan it for codes. The fact that you disconected the MAF and it runs better tels me that the maf sensor is broken.
Also check the battery as mine did this sort of thing
Cheked the battery now 12,86 volt with the engine off and 14,37 volt when ideling so the battery looks good
Get a tdi octavia less problems, my mate has a scanner, hes in fjell near bergen i could give him a call
download vcds lite and buy this cable
http://www.ebay.co.u...=item4d026febe4
then youll get all the info you need, and post results up here if your stuck
£6.85 instead of £100.00 bit better eh?
Hi
Thank you so much, I just ordered the cable now and we'll see what the car hiding of error codes:
now the check engine light been on for a week but when I went to use the car to the shop today the light was off and the car behaved normally.
but probaly not for long so the cabel will be good by hand
