Help needed
Hi guys need abit of help,lately the vrs has been abit lazy on start up so i thought id charge it overnite so ive gone to put it back on and dashboard has picture of steering wheel,car with wiggly lines behind it,tyre pressure light and esp light on centre of dash is on
Please help not sure what to try missus due to go out with nipper,hoping for quick fix
Cheers guys
Mark
Car is 2006 2.0tfsi
Those lights always appear after disconnecting the battery. A short drive should sort them. Though if you're on your original battery I'd say it's on its last legs anyway and you should be looking to replace asap.
As above, the lights should go out after a few minutes driving.
If its the original battery and it starting to struggle then it's time to invest in a new one to avoid your wife and kid been left stranded somewhere.
Your right there a new 1 will be got 2moro,cheers for help guys
Big thanks mark
Re-align the throttle body with vag com . After the battery has been disconnected the timing is not quite right. Takes 5 mins. Much smoother after
If the battery seems weak, charging it isn't going to fix anything. The battery charges every time you drive somewhere. It's likely time for a new battery.
