Washer bottle !
Can't find wear the rear washer bottle pipe connects on to in engine bay. For rear wiper
At the bottom think it's the side nearest inner wing, hard to get to
Sent from my Galaxy S3, not a Crapple!
I can't get to it at all. Would e easier if I take the iner lineing off the wheel arch off get to it or no ??
Why are you trying to get at it? If the rear wiper was has stopped it usually comes off in the boot
Because ever since I had the car the rear wiper washer never sprayed any water . But can hear the motor work but no water . So got round to looking at it. And the pipe that come from washer bottle at the bottom have cum off and can't see wear it goes bk on. And going from the other post earlier. It's realy hard to get at . So trying find best way attach it bk up and get to it . Any ideals ?
Mine had the same problem as long as yours haven't got the headlight washers here's what I did.
Loosened the charcoal canister so it was moveable, took the screws out holding the washer bottle and moved it so I could get my hand down and popped it back on
Ok . Thanks for that tip. Ill do that in the week .cheers. .
I got to mine via taking out my arch liner
Edited by guss84
That's a point my washer fluid came out next to the front wheel when I tried the rear washer is yours doing that?
Yhh that's how I new the problem was up by the washer bottle Cus . The water was ****ing out off bottom the wheel arch Wen tryed use the rear washer. So had look wear the littler motor is attached to the side off the washer bottle an gently pulled one off them realising it was lose and was off. Just thinking wats goin be easiest do now. Take liner off wheel arch off or remove couple coponents near the washer bottle make it more assemble !
Defo easier to go in from the top I would say
Yhh think goin do that wen get time. Chers
