Mfsw retro fit problems.
I'm trying to retro fit a mfsw to my octavia 2.0pd. So I have the steering wheel, airbag and new steering controller.
Steering wheel and airbag fit and airbag light is out.
None of my buttons work. Nor does my horn. Infact the horn turns of cruise control when I'm driving.
Part numbers
Steering controller. 1k0 953 549 g
Slip ring. 1k0 959 653 c
These should work I think. But they don't. Any ideas.
I take it you have fitted a Mfsw airbag loom?
Also that you have coded it properly?
How old is the car? manual or DSG?
Can you post a scan up of the steering wheel controller before and after the coding
Which steering wheel are you trying to fit?
A FL or a Pre-FL? Is your car a pre-FL?
yes i have fitted one of these, if it is the wire that goes from the slip ring to the buttons,
not overly sure how i need to code it, i tried to code it in the steering controller, and the can gateway, no joy
the car is 2006, pre facelift, manual.
i have put my original controller and steering wheel back on so i have a horn.
i think it is a face lift steering wheel and airbag, to a pre facelift car, could this be my problem.
I think so. The FL wheel has rollers on them, the pre-FL just has rubber buttons.
When I enquired about doing this mod no one could give a definitive answer as to whether it would work or not. So I didn't do it and bought a pre-FL 4 spoke.
I did get one positive answer from Cars Equipment which said that it would all work except Maxidot control from the MFSW.
I think you need a 'CH' steering controller, not sure which loom (FL or Pre-FL) and obviously the FL wheel & airbag. Then you might get some of the MFSW functions working. I think you also need a fairly recent CAN Gateway as well.
It was too much of a costly risk for my liking.
If the only answer I got is correct, then persevere with it and try coding it differently.
Have you got a scan from your car showing the steering controller (new one) and CAN (& I'm sure there's another location that the MFSW needs to be enabled as well - possibly radio).
The wheel and airbag didn't cost me anything. So only down on the steering controller. I'll change all again and post a scan as soon as I get a chance.
Before you change them save a scan of your current coding so I can compare to the ones I have.
Scan before i change anything
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LD HW: 03G 906 021 LD
Component: R4 2,0L EDC G000SG 8514
Revision: --H02--- Serial number: XXXXXXXXXXXXXX
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 6CDCC34A4FEBFA78EDD
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0006786
Shop #: WSC 73430 790 00000
VCID: 71E2D23E68C91790DEB
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1Z0 820 047 K HW: 1Z0 820 047 K
Component: Climatic PQ35 140 0909
Revision: 00140009 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 3B7E30167A05ADC0347
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003962627
Coding: A18803331004140000110D0000000000000100005C
Shop #: WSC 28055 576 13846
VCID: 2B5E00568A653D40A47
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 011208 022 0601
Coding: 00055223
Shop #: WSC 28055
Address 10: Park/Steer Assist (J446) Labels: 1Z0-919-475-V1.clb
Part No SW: 1Z0 919 475 C HW: 1Z0 919 475 A
Component: PARKHILFE 8K H06 0006
Revision: -------- Serial number: 66541002000855
Coding: 100003
VCID: 418242FED8E9C7106EB
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 R HW: 1K0 909 605 R
Component: Q4 AIRBAG VW8 018 2200
Revision: 02018000 Serial number: 0038MD0A6AH3
Coding: 0020788
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000042
VCID: 76E8E12201A730A80B9
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1Z0 920 941 D
Component: KOMBIINSTRUMENT VD1 0918
Coding: 0000401
Shop #: WSC 20022 576 12536
VCID: 38742F1A4B3386D8D95
1 Fault Found:
00003 - Control Module
014 - Defective
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4540K10314821A
Coding: E9A07F04400212001303
Shop #: WSC 27011 210 12515
VCID: 69D2BA5E4019EF5096B
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 0918
Shop #: WSC 24004 576 02201
1 Fault Found:
01176 - Key
008 - Implausible Signal
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7662176900
Coding: 010000
Shop #: WSC 05314 000 00000
VCID: 2952FA5E40992F5056B
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 A HW: 1Z0 035 680 A
Component: RNS-MID H04 2724
Revision: AB001001 Serial number: SKZ6Z7H9066073
Coding: 080004000101008000
Shop #: WSC 31414 790 00001
ASAM Dataset: ------------------------- ------
VCID: 2E58094279774868839
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2346
Coding: 0000756
VCID: 36682122412770A8CB9
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 346C1B2A575B62B8F5D
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19D002007F2D8D0DC85F851004CC
Shop #: WSC 73430 790 12345
VCID: 79F2EA1E30B95FD066B
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE No Answer
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000764
VCID: 37762C26462D89A0D0F
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2435
Coding: 0000144
VCID: 32601D32AD4F6C88E71
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
VCID: 336E183652556580EC7
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007662072084
Coding: 0200000100010110
Shop #: WSC 00152 210 91233
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA_VW36.rod
VCID: 2648F162598700287B9
now for the scan after all is changed, no coding done yet
Coding: 0000072
Revision: 00H13001
Coding: 0006786
Coding: 00055223
Shop #: WSC 28055
Coding: 100003
Coding: 0020788
Part No SW: 1K0 953 549 G HW: 1K0 953 549 G
Component: Lenksäulenmodul 521 0050
Coding: 0002042
Shop #: WSC 01279 785 00200
Coding: 0000401
1 Fault Found:
014 - Defective
1 Fault Found:
01176 - Key
Coding: 010000
1 Fault Found:
03138 - Input AUX IN
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 163
Mileage: 200065 km
Time Indication: 0
Date: 2000.00.00
Time: 16:19:03
Coding: 0000756
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Component: KSG 0401
Coding: 0000764
Coding: 0000144
Coding: 0000144
I notice your original AF controller was Software Level SW 0070, but the new G controller is Software Level SW 0050, so you are now running a lower software level than before? Not sure if this is going to be causing your issues?
Coding: 0000042
Coding: 0002042
after coding still not working
Coding: 0000072
Revision: 00H13001
Coding: 0006786
Coding: A10803131004140000110D0000000000000100005C
Coding: 00055223
Shop #: WSC 28055
Coding: 100003
Coding: 0020788
Coding: 0002042
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
004 - No Signal/Communication
Coding: 0000401
1 Fault Found:
014 - Defective
Coding: E9A07F06400612001303
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 203
Mileage: 200065 km
Time Indication: 0
1 Fault Found:
01176 - Key
Coding: 010000
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 163
Mileage: 200065 km
Time Indication: 0
Date: 2000.00.00
Time: 16:19:03
Coding: 080004000101008100
Coding: 0000756
1 Fault Found:
000 - -
Component: KSG 0401
Coding: 0000764
Coding: 0000144
Coding: 0000144
I don't think the SW HW on the steering controllers is the problem
what airbag loom did you use?
what wheel have you fitted?
Facelift wheel and the loom that was on the wheel and airbag. Airbag is coded ok and lights work on the buttons work.
Is this controller the most up to date one available.
Is this controller the most up to date one available. 1K0953549CH
I should have read all the posts.
If the buttons didn't light up, then I would say it is definately the controller.
It could be that you need to try a CH Controller as this was required for fitting newer type wheels in VWs. that would be a Lin 2 version
also have a look at the coding in the Columbus. Try shortpress buttons in the coding or if it is ticked, untick it
