Cambelt
Getting my cambelt done in the coming weeks, what do I need to change? Waterpump, belt, anything else?
If there is anything else, what are the part numbers?
Cheers guys
Mike
just had mine done a couple of days got all my kit from eurocarparts http://www.eurocarpa...e3abb057 that kit also included the hydraulic damper and according to eurocarparts that kit is what Audi uses just has skf stamped on it and water pump you want a metal impeller so i went with this one http://www.eurocarpa...ce5d4a75 couple that to the discount code service 30 all came in at £105.84 which i can't complain at all !!
Edited by vrs 180t
Thanks mate, just what I needed.
Might be worth doing the aux belt at the same time as it comes off anyway, mines started squeaking on start up just after the cam belt change, new one was about 9 quid at a factors :)
