BWA engine tfsi damaged , what to replace with
06 Lack of oil killed my tfsi , blowing heavy exhaust smoke threw oil filler tube , rings or valves i would say ...
which engine code can i replace it with ?
Id fit the engine from an S3 and go K04 stage 1.
harry blew up his and replaced it with a low mileage edition 30 engine IIRC (k04).
any 1 got a good link , see what bits i need ecu , wiring ect
would i have to go with the AXX/BGB/BPJ/BPY/BWA
or could i used cdl with bwa wiring loom
Edited by Quick Silver
So is it blowing oil out of the filler cap? Are you sure the engines blown?
Thick Exhaust smoke alittle oil but alot of smoke compression test seemed ok 190-200 but will test again , unless exhaust gasses are directed into cam cover there is a big problem some where . pcv valve seem to be working ,
