first fault with sdi
Ok well more of an inconveicence. The power steering fluid resevoir is under the battery what a pain in the backside to just check the p s f level as occasionaly when cold the ps warning light comes on no ps then switch it off and back on again no warning light and steering is fine any ideas why? Bob
Edited by big bobz
I reckon it probably needs a new battery. Does it still have the factory
battery in it? If so it's probably quite tired by now.
There's a 60 amp draw from the steering system so if your battery is low
or worn out it will play up and cause all sorts of warning light gremlins.
If the headlights are on do they dim or flicker when you go lock to lock?
Another classic sign of tired battery.
http://www.tayna.co.uk/E44-Varta-Silver-Car-Battery-577400078-P7726.html
Put one of these rudeboys on and you should be okay.
Great battery and a significant upgrade over the std unit.
You can check the fluid when you swap em over :thumbup:
Excellent battery seller too, try and find the same item elsewhere
a bit cheaper and they'll price match or drop the carriage fee.
(They did for me) Battery was delivered in excellent packaging and
came very quickly.
Forget it. Mine has done this for 3 years plus. On mine it's a winter thing, it's to do with the battery giving it's all to starting and the glowplugs. The chances of it having anything to do with the fluid is very small. A new battery may help.
