MAF Sensor Help
Hi,
I have recently bought my first Octavia 1.8T and i am working through a list of DTC's. The first one I'm trying to solve is fault 16486 MAF signal too low. I have run a log of block 002 on VCDS and the MAF is pulling 121gm/sec @ 6050rpm which seems fine for a 150bhp engine. However at idle the figure is ranging from 0.8 - 1.6gm/sec which seems much lower than the 4 - 5 gm/sec specified.
Before I spend out for a new MAF I was wondering if any one else had experienced a similar problem and how they overcame it, I can post a copy of the log if that helps.
Stuart.
check for air leaks
look at the vacuum pipes under inlet manifold
When mine was playing up it was at the top end, it was up and down like a whores drawers, fine on idle and low revs
HTH
HTH
GASP language David :angel:
Language ??
Since when was drawers swearing
I'm surprised it wasnt masked by the censor list. Haha
