Vega wheels
Right, took those monster centre caps off the wheels. Kinda think they look better without the monster caps. However, there is a hole in the centre that could do with being capped.
Anyone know what size the centre hole is on a Vega?
What the bore or the actual hole?
Hmmm, what size caps do I need? (might be a better question)
Pretty sure that'll be a no go. The centres of those wheels (the inner hole by the hub) which you'll only see without the large centres in place, probably won't have a lip to engage with the spring clips on a small centre cap, even if you found one of the right size.
You can't get a normal clip/spring cap in no. Had mine off this morning.
Oh bugger! ;)
Thanks guys. I think I'll stick the monsters back on.
