MK4 Golf ARL 150 TDI
I have asked on the Golf forums but had no replys ................
Need Some help please...........
Started the Car the other Morning and Engine Management Light came on?
Drove the car but no boost.
Got to work and used a code reader for faults..
P-0236 & 18000/P1592/005522
Help required, I have no boost and replaced the N75.
Checked & cleaned earth points & checked wiring from N75.
Solenoid Valve (A) for Boost Pressure Control (N75)
Possible Solutions
  • Check Fuse(s)
  • Check Engine Electronics Power Supply Relay (J757)
Where is the fuse for this item??
Relay J757 where is this positioned?
Which sensor is G31?
Any advice appreciated, thanks.
is the car smoking under load?
check for boost leaks from pipes
check the turbo actuator to see if jammed
i would suspect variable veins seized rather than n75
check the vacuum hoses that go to n75 and turbo
