Anyone Near Sheffield, South Yorkshire with VCDS/Vag.Com
Hi All
Thinking of retro fitting a cruise control stalk some time soon on my VRS and was wondering if anyone locally would be able to sort out the coding once linked up?
Will also sort a thank you 'drink'
Thanks All
I could do it for ya.
Chris,
Do you know your way around coding for Xenons for a 2007?
I currently have mine coded as Xenon's without shutters and the cold diagnostics off and they work fine with a 50w kit but I have a bulb out warning on the dash that seems to be associated with a headlight adjuster fault, even though both work fine.
I'm therefore wondering whether to try turning off the Xenon without shutter coding and just leave the cold diagnostics off, clear the bulb warning and see if that cures it but don't have ready acces to VCDS...
You're more than welcome to pop over and we can have a look...
