helpppp...
hello i have a mk1 skoda octavia tdi elegance
its been playing up a bit lately, clocks have been resetting themselves and giving me dodgy fuel reading after they reset (300 miles to a full tank is what it reads)
anyway its got alot worse lately , today when i started the car the clocks reset but when i stopped it wouldnt lock the car and the interior light wouldnt turn off, i plugged the code reader in and got the following codes:-
01314
01316
01321
01315
01336
01304
01299
00849
alot of codes say dtc in description
theres also a relay clicking under dash when rpm reaches 2500 but only until the car warms up a bit ,
ive resently changed thermostat and temp sensor
any light woukd be appreciated
Unsure about codes until later. But the relay clicking at 2500 revs is normal when cold. Clicks once on way up past 2500 and once on way down past.h
Most of these fault codes relate to communication isssues between varios modules on the car,either a wiring loom fault or your can gateway module is faulty.
The last fault code 00849 is a ignition switch issue again check wiring and fuses.
For advice check out the Ross Tech Wicki site,
ok thanks for reply , can you expand o what you think the problem could be , when you say the loom do you mean the whole thing or just a section , can gateway faulty ??? :S
Hi,
I would first try and fix the last fault code which is a igntion switch problem where one of the switched outputs is missing, this could possibly be causing the other errors,all the rest of the faults are can-bus communication faults betweem the varios electronic control units on the car, check as many wiring loom plugs as possible in the varios controllers, eg. instument panel, engine ecu, abs unit etc.The fact that nearly every unit on your car is showing a can bus fault points to the can gateway module which controls the communication can bus lines which run at different speeds depending as to whether it is a drive system or infortainment system.
.It is very difficult to give advice on these issues on line without knowing a persons capabilities,these can be difficult faults to rectify even for the most compitent engineer.
Edited by freelanderman
