Low front is getting on my nerves
The overly low front on my Octavia is gettin my nerves, has anyone found a way to increase the clearance without too much cost?
Haha, never had it this way round. Depends what you want to lift, if its engine, I used 20mm engine and gearbox mount spacers. If its the suspension itself, you could go with graystone spring assistors. They sit between the coils and lift the car a little but also stop the bottoming out.
Get your front shocks checked. Mine were worn out when I removed them to fit coilovers. Car rubs less now it's stiffer even though it's lower
You could fit springs from a non vRS to raise it 15mm
OP says he has an L&K.
Springs wear low with mileage, so a new set of front springs might sort it. Could you measure the vertical distance from the wheel centre to the arch top?
Cheers for your replies
I suspect the suspension is indeed buggered and needs work, bushes dampers & springs which will probably resolve the front rubbbing.
All makes perfect sense.
What would you expect this to be please?
Cheers, Terry
Cheers, Terry
I can't remember the official distance, but I get 3 fingers, about 60mm, from the tyre top to the arch; car has done 110_000 miles and has same size wheels and tyres as a stock L&K.
pain in the backside they are too low and i struggle to get over speed bumps, there is a road just up from me and the bumps are massive and i always scrape the engine cover try to avoid that road as much as possible.
i have the same problem........
:bandit:
