Router Config - Help Please!
Hoping one of you can help. I am running Exchange 2010 and it is all configured correctly and routing emails both in and out however I am wanting to allow users the use of web mail externally.
If I browse to the IP in question I am presented with ASDM login of my router and if I telnet to the IP address I am presented with CLI of my router. See the config below - What do I need to add to tell the router to forward the requests to 192.168.1.54 (Exchange Server) - I have thought of DMZ but in order to do this an additional port is required on the router and I don't have another port to do so.
I have filtered out certain bits of config.
Router#sh run
Building configuration...
Current configuration : 6985 bytes
! Last configuration change at 00:39:19 London Fri Nov 30 2012
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
hostname
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network sdm_vpn_group_ml_1 local
aaa session-id common
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168
ip dhcp pool dhcp
network
dns-server
default-router
ip name-server
ip name-server
ip name-server
ip name-server
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
crypto pki trustpoint TP-self-signed-
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-
revocation-check none
rsakeypair TP-self-signed-
username
crypto isakmp policy 1
encr 3des
authentication pre-share
group
crypto isakmp client configuration group
key
dns
pool
max-users
netmask
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map SDM_DYNMAP_1 1
set security-association idle-time 3661
set transform-set ESP-3DES-SHA
reverse-route
crypto map SDM_CMAP_1 client authentication list sdm_vpn_xauth_ml_1
crypto map SDM_CMAP_1 isakmp authorization list sdm_vpn_group_ml_1
crypto map SDM_CMAP_1 client configuration address respond
crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
interface FastEthernet0/0
description <<Internal Facing>>$FW_INSIDE$
ip address 192.168.1.1 255.255.255.0
ip access-group 100 in
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description <<Internet Facing>>$FW_OUTSIDE$
ip address dhcp
ip nat outside
ip inspect SDM_LOW out
duplex auto
speed auto
interface ATM0/0/0
no ip address
shutdown
atm restart timer 300
no atm ilmi-keepalive
dsl operating-mode auto
ip local pool
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat pool NAT
ip nat inside source route-map SDM_RMAP_2 interface FastEthernet0/1 overload
ip nat inside source static tcp 192.168.1.54 25 interface FastEthernet0/1 25
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/1 overload
access-list 1 remark Allow IP Range
access-list 1 permit 192.168.1.0 0.0.0.255 log
access-list 2 remark Allow IP Range
access-list 2 permit 192.168.1.0 0.0.0.255 log
access-list 100 remark Generated by SDM
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip host 255.255.255.255 any log-input
access-list 100 deny ip 127.0.0.0 0.255.255.255 any log-input
access-list 100 permit ip any any
access-list 101 remark Generated by SDM
access-list 101 remark SDM_ACL Category=1
access-list 101 permit ip 192.168.1.24 0.0.0.7 any
access-list 101 permit udp any any eq non500-isakmp
access-list 101 permit udp any any eq isakmp
access-list 101 permit esp any any
access-list 101 permit ahp any any
access-list 101 deny ip 192.168.1.0 0.0.0.255 any log-input
access-list 101 permit udp any eq bootps any eq bootpc
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any log-input
access-list 101 deny ip 172.16.0.0 0.15.255.255 any log-input
access-list 101 deny ip 192.168.0.0 0.0.255.255 any log-input
access-list 101 deny ip 127.0.0.0 0.255.255.255 any log-input
access-list 101 deny ip host 255.255.255.255 any log-input
access-list 101 deny ip any any log-input
access-list 102 remark SDM_ACL Category=2
access-list 102 deny ip any 192.168.1.24 0.0.0.7 log-input
access-list 102 permit ip 192.168.1.0 0.0.0.255 any log-input
access-list 103 permit tcp any host 192.168.1.54 eq smtp
access-list 103 remark SDM_ACL Category=2
access-list 103 deny ip any 192.168.1.24 0.0.0.7
access-list 103 permit ip 192.168.1.0 0.0.0.127 any
route-map SDM_RMAP_1 permit 1
match ip address 102
route-map SDM_RMAP_2 permit 1
match ip address 103
control-plane
line con 0
line aux 0
line vty 0 4
scheduler allocate 20000 1000
end
Router#
Anyone?
Might be a bit confused, but my understanding is that you have a single world IP and the router listening on this IP is using port 80 for it's own web server, running the router's admin pages? If that's the case, I think you'll be needing to do some port juggling to either move the router onto an alternative port or create a port for webmail. Once you have the Exchange ports available, just port-forward all traffic arriving on them to the Exchange server....
Chris
Thanks Chris. Already know this - What I need to know is what bit of config needs amending there to tell the router when requests are received to forward onto the exchange server.
Do I just add another ACL?
It's not your ACLs, it'll be your NAT settings. You only have port 25 forwarded to Exchange, not port 80, which is why it's being received by your router and handing you the login page.
Don't forget 443 since by default exchange 2010 will want to use that for OWA, how have you set IIS up? to take the http and forward the https /owa subdirectory?
Also, I just spotted your NAT commands are just dumping traffic out of an interface without rewriting the IP address. This probably won't work, because when it reaches your Exchange server it might still have the original destination address on it, at which point your server will see traffic that "doesn't belong" to it and is probably silently dropping it. You need to get the commands to translate the headers in the packet from your WAN IP to your Exchange server's IP and not just throw them out of a specific interface, forward the right ports rather than using overload, and you should be up and running.
edit - actually, this post is total cobblers. I read the command the wrong way round, oops!
Edited by gac
Thanks. I will try add to that NAT statement. See if that helps!
you probably need to adjust the management ACL to only accept traffic from your internal subnets/interfaces. I THINK by default it will accept from anywhere.
then NAT the incoming traffic on TCP80 and TCP443 to your internal server IP
Changing the statement worked guys.
Cheers.
nice one, glad its working for you!
