18" Tyre Pressure?
Just wondering what tyre pressures people are running in thier 18's
37ish seems to be about right!?
I've tried a few different combos but 37 all round works for me
Same wheels as me too. I've been running at 30-32 but didn't have any figures to go on. Anybody else?
Sent from my phone, using my thumb.
On my 18s I run 31 front 33 rear.
Most wheel places will tell u that u run the same pressures ;(
But i find that if you do that they look flat
Its abit trial n error mate, pump up see how feels then just nose at wear
When i had 225/30/20s i was running 35f36r
With my 215/35/19s im running 34f/35r
They have a diddy stretch so i put a bit more in to push middles up
Goodluck mate :)
A lot of it is personal due to loads etc, I regularly have 4 adults in mine for lift sharing to work so run them slightly higher, it doesn't seem to affect grip or wear
I've always found you need to tweak the pressure according to the specific tyre, using the OE stated pressure as the 'min' pressure required
Its trial and error after that to get optimum pressure for conditions
Some tyres specifically require higher pressure to operate correctly, eg winter tyres
Off on a tangent, anyone used one of those remote tyre pressure monitoring systems ?
They have them in a works bmws! After having a high speed blow out about 1 min later the very helpful i drive system told me we had list tyre pressure! Needless to say I don't particularly trust them
