Skoda Felicia Thermostat Seal?
Does anyone know the specifications of the thermostat seal for a 1.3MPi Felicia?
I did buy a new thermostat but it came with no seal. :/
There is a workaround for your problem: Red RTV High-Temp Silicone Gasket Maker.
But if you really want a rubber replacement, here you go:
Material: EPDM (Ethylene-Propylene-Diene-Terpolymer)
Inner Diameter [mm]: 47
Outer Diameter [mm]: 55
Height [mm]: 4
Cheers mate! I'll try to order one from my mate. Either that or try to get one from GSF. :/
