clutch wont engage
hi need some help last night car lost all drive and clutch would not engage. checked slave cylinder for any leaks but there was none also brake resevoir is full.
there has been no clutch slipping/dragging prior, gear change was smooth and clutch engage and disengaged smoothly.
i have had the clutch pedal replaced with the modified one due to the box braking not sure about the master cylinder tho.
could it be the clutch itself or the release bearings.
any help would be appreciated.
If the hydraulic side of things looks ok, no leaks etc.
..then it really points to a mechanical fault, so most likely box off to investigate further.
