DIY: LED Boot Light
Ironic how Im doing lighting mods in the dark.. anyway, bought two pairs of 3w led DRL lights (£3 posted per pair), one is planning to be under the wing mirror acting as a puddle light, the other is used as a set of LED boot light. Its not complicated so I'll just show you pics, if you need more details let me know...
This for reference which is +ve and ground:
Stupid boot panel has 2 screws, 2 plastic nuts (of which the spare wheel needs to come out to be undone!) and 5 push in clip things. I drilled holes to poke the LED light through like so:
Looks like this on the other side (side of which you will see):
Finished product. Boot is messy yes, but I can see exactly how messy now lol:
Better than the LED strip I was originally going to use.
Thanks for reading :)
Awesome work!
I've bought some led's to try and improve the lighting in the boot. A lot less hassle than your effort, but I'm sure the results will also be half of yours!
Fair play sir!!
Nice mod there. :thumbup:
Very nice!!
One of those things I've always quite liked to do myself but never gotten round to. I also never settled on a location, in the plastic trim is a nice touch though!
Love it mate, looks very good and even oem
Thanks,
Black anodised version also available but cost a little more. I bought cheapest ones I could find to test really.
Do they stay on when the tailgate is closed?
Looks good, something that needs to be done since the standard lighting is crap!
I assume not? It's just hooked up to the original connections :)
Sent from my GT-N7105 using Tapatalk 2
Whip your parcel shelf out and lock the car and have a nosy through
the window when it's dark... It's possible that they may glow dimly which in turn
may cause battery drain, which in turn may cause false alarms, especially in winter.
I rigged up an LED strip to my Fabia bootlight and had all these issues,
not so much of an issue if the car is driven all the time but in mine which
went out once every week or two the problem became a pain in the butt
and I fitted a plug to it so it would only work when plugged in.
It's caused by residual voltage in the circuit even when off which is enough
to make LEDs glow a little.
Ahh, thats probably why I put a diode in there.. lol I knew I had a reason why I left the diode in there before.
That should take care of things then, great install by the way. Love the way
they illuminate the boot floor.
Whoa, fabias have boot lights?
The missus 1.4mpi Classic (W reg) doesn't...not that I've ever found. I just classed it as "silly design", like the lack of external boot release..
Got a pic of how and where you've joined the wires to the original connector/light unit?
No boot lights or boot opener? Oh dear, are you sure it's a Skoda? :think:
Our W reg has a boot light in the left hand (viewed into the back of the boot) side just by the speaker grill and it also has a remote boot release.
TBH I don't use either as the light is blocked by your body when using the boot and I just unlock and lift the boot lid. The LED setup here might be just the answer to the first issue: many thanks JLneonhug.
Question - does the diode fit on the live (+) into the LED? I'm not sure how it would stop any residual voltage effects, but my knowledge of electronics is nil.
Mm, I looked at he speaker plastics/shelf support panels for one as thats where my Astra has it..nothing. Unless a PO has removed it. I had that down as a design oddity. We have the remote boot relese by the drivers seat, but it's a PITA, as the boot doesn't "pop" as such, and you need 1 person moving the boot as the other pulls..heh.
Just an update, for some reason using these LEDs and diode combo; the light is on slightly still when boot is shut, didnt happen with those replacement 501 led. As a temp solution I put in the original bulb in to draw some current across when boot is close. I'll probably put a low ohm resistor across it (much like canbus LEDs) when I have time measuring the current draw when boot is closed.
Diode has a forward volt drop (0.7v? or 2.7v? I dont remember) so I assumed that would be enough to stop the lights from coming on but as explained above it need a resistor in parallel to lights to stop LED from lighting.
Ha, I striped the wires and twisted it together on the "]" bend (see first pic where the bulb is shining)..... This is testing stage at the moment.
But if I were to do it properly, I would get female crimp terminals and stick it where the bulb fittings are. Alternatively, remove the light casing altogether and use male crimp terminals and plug them directly into female plug.
Would it not work if the diode was soldered directly to the positive wire on the additional lights?
That looks brilliant!! Brilliant MOD for sure! Only yesterday was a searching around in the boot with the torch off my phone :whew:
Couple more pics:
Yeah that can work too. It was easier my way though as it doesn't effect normal operation even with standard bulb in. (though like I said previous post you'll probably need resister in parallel if your only using the leds).
The only issue I would have with that location is 60 per cent of the time something is likely to be covering that bit of trim (in my boot).
Oh? I normally load things from inside outwards. I give you that putting a pram in will block most of the light but the pram kind of blocks everything. Alternative location is drilling a hole where the removable panels are for the rear light, then you'd have to make the lights detachable too, which is more of a hassle.
i.e.:
http://www.ebay.co.uk/itm/DC-Extension-Lead-2-1-X-5-5-mm-Plug-and-Socket-Male-And-Female-Connections-/230891533351?pt=UK_Computing_Sound_Vision_Audio_Cables_Adapters&hash=item35c2353427
Or simply spade connectors...
My fault for having a big massive subwoofer and amp taking up half the space though, lol
Ah.. Ic lol. Off topic, why is the facing the sub that way? Would've thought it would give better sound and save some space if faced the other way.
