Radio removal
Does anyone know how to remove the radio from the citigo without scratching or damaging anything?
Also is there a way to get to the battery from the cabin to get a feed?
Thanks.
Stu.
The are two slots in the radio facia, I'm only guessing that these are maybe to insert removal tools.
Mick
Yes , but with the surround of the heater controls included within the fascia there are probably screws or clips involved somewhere and I would rather attempt it with some prior knowledge if anybody has done it.
Thanks Greenstripe. Very good tutorial.
Anyone know if you can get to the battery from inside the cabin?
If you want a 12v feed the fusebox is in the driver footwell.
I've got my drive recorder wired into it. :)
It's for an amp so it will need a thick wire for the current so ideally could do with the battery terminal.
