Alternator "broken wires" PTC dosent work :( help anyone?
Yes i got first this proplem when i turn my keys in second posession "ingnitions pover on" so batterys lights dosent turn on. So i fix it and then it start work ok. But 17911 - Load Signal from Alternator Term. DF: Implausible Signa it still show on. Sometimes ill get it clear. But i havent get works correctly....or anyone better informations which mesure block shud show me alternator LOAD % if im understand right if ECU dosent get this load information MY PTC element dosent start at all :( My alternator works well i get litell pit over +14V when it runs ideling and it dosent go under +13 V even i but everything on...And it start my engines well even we have minus 10-15 degrees here now
Thank you
Have you cleared the original fault using a scan tool or vcds?
Yes i use vcds and i have done it 2 different ways...First i just do auto scan and clear all fault codes away and other way i just choose engine and chek codes and clear it away.
And yes after these method i take keys off and but them back start engine and chek fault codes and it dosent found nothing...
When i check my clima ( semi-auto) auto-hvac box there is these fields which show me....z35- on/off depends if i turn cold or warm/hot and all so there is this alternation load % which show me 00% and few other field.
I found somwhere information and there was saying if ecu dosent get alternation load% it dosent put this ptc elment on..
but after all this same fault codes came back
Check the wires for continuity with a meter.
Check the engine earth under the battery - particularly where it mounts to the body.
Heya :) i fix this proplem..well i just do again what i have try to do earlier: http://www.seatcupra.net/forums/showthread.php?t=209472
and this was allso issue how to get this fault code away....And it works this time i just do better work ;)
Thanks to helping me anyway :)
Ouh and now my PTC start to working too :)
  • 2 months later...
Lets put some moore informatio what else you can found wrong your car out if these 2 wires is broken...
Well sometimes steering wheel can feel heavy (it goes off too if battery voltage is too low) sometimes when i star engine and i try turn wheel nohting happend first but when i give moore rpm on engine it start to work again. (first i think do i have some problem whit my powersteering system)
All so this ASR light can be start on after 5-10 min driving..
And if you made fault scan you can found out battery voltage too low notification.
So im soo happy than i get this problem to work ...Now my car is so warm so fast and even better for me :)
