Cracked N/S/R light cluster
Happy New Year to all. Managed to crack the light cluster when reversing, only a hair line crack but noticeable. My question is any advice on where to purchase a new one preferably a genuine Skoda part, had a look at Eurocar parts but unsure if genuine, also how easy is it to replace.
Rear cluster doodle to change
Open boot remove plastic cover
Theres a screw handle undo this (might be a bit stiff if you havent ever undone it before)
And make sure your holding the light pushing towards car will.make it a bit easier to undo
And thats it disconnect the plug an its out.t
Might have to give the cluster a bit of a wiggle to lossen up from the bodywork and pull out
Refitting involves
Putting plug in to cluster
Slotting light into the holes and the screwing in making sure to hold and position how you want because it can sit differently
Of you find what i said difficult if tou find the rear bumper removal guide ahould also mention in there about light cluster removal
Try a breakers yard/car dismantlers. Plenty are now on the web so can be easily accessed.
My local one was breaking a Mk2 vRS but as I'm on the south coast and you're in Scotland possibly not the nearest but i suspect they may post if suitable.
http://www.silverlake.co.uk/breakers/details/2010/skoda/fabia/vrs+s-a/petrol/hatchback/green/automatic/bc9348/
Not sure what removed means in the discription in whether it is sat on a shelf waiting for someone to buy or whether it means removed and therefore sold.
JT
£50 tops eBay hundreds there
