got my bits and then got to work.......
Hi All
I got all my bits in the poast today:
The finished look:
It shows volts then switches to boost
This was it before:
Better i think.
Thoughts marko
like the DV, not the position of the gauge though. If you are sticking it in the vent then why not get a vent gauge pod that you can get to fit in the drivers side vent
Although I got fed up without having a heater vent so made my own.
found here in techi section
http://www.briskoda....oost-gauge-mod/
i got those gauges.. not bad are they. you know under the sticker on the back theres 2 switches to switch between bar/psi and voltage sweep on or off. :)
gauge looks just a touch pikey to me if I'm being honest, I mounted mine in the same place but took the time (lots of it lol) to do a tidy job of it, I'll post up a pic in a minute, in short though it's a good location but needs the slats in place and the gauge surround painted matt black, looks a bit bright too so maybe a resistor to dim it down slightly.
Edit to add - I mean the mounting of it is not great the gauge itself is tidy
Edited by Keirravn
Crappy iFail pics but you get the idea, like I said took a while to make but well worth it in the end :)
Nice ! What gauge is that ?
Cheers dude :) (presuming you mean mine lol)
It's one of the prosport gauges, idea is it lights up white with ignition then changes to green when you turn the lights on. I found it a bit tricky to the brightness right though (its really bright as standard) so have just set it to green with a resistor to dim it down
the vent isnt finished yet, im going to add the slats to finish it off, as for matte black think im going to keep it silver to try and match it in with the silver on the std gauges.
This is the gauge:
http://www.ebay.co.u...984.m1439.l2649
I have set it to PSI and kept the voltage run on (quite funky)
Marko
Ah see, ye should look tidy when done its a much better location then off to the right I reckon :)
It was a bit of a toss up for me deciding whether to leave it silver to try and match, but I reckon black leaves it looking less in your face and more oem which is what I was after, be good to see the finished product man
Thanks Mate, i prefer it on the left think it looks better, im going to try and get it finished this weekend but dont no how much time i will have ( the misses wants the hall flooring down asap lol) plus i need to get a vid up of my car on idle and driving normal and hard to put a end to this:
http://www.briskoda.net/forums/topic/260906-full-25-ss-with-de-cat-and-all-boxs-gone/
I will get pics up wen it finished.
Marko
Split - r valve! Noooooo
Heres a vent pod! Looks nice and original
It Better than an atmospheric one and it still re-sirks and i get the tisssss i want, all god imo........
Looks just like this on but on a diff vent......................
my one will look like that one soon ( if the misses lets me lol).
marko
yes but a 007p gives the tsch noise when you team it up with an induction kit, the split r is only good for dumping boost which isnt a good thing
