Dipping wing mirror at it again.
Just got home and again after selecting reverse mirror moves looks upwards instead of down and can only see top of hedge in passenger mirror instead of low wall next to parking space.
Has happened before but may clip wall if unlucky. Seems to be keen to get it up rather than down
Ok with normal mirror on Octavia but I have found this bit of technolgy very useful.
Over to you boys TP, Graham, Richard, Cheeky Steve and the rest of you Yeti boys
Peter
Ps Happy New Yeti Year.
From Yorkie Calendar boy March 2013
Haven't got a clue, Peter. Dewi lies in the manual KISS school, thankfully.
Sounds like a control unit gremlin; come across passenger windows that open with the drivers window switch, which is similar (possible car getting confused between being left or right hand drive :wonder: ).
There may be a hot fix without taking it to the dealer but sadly I've not come across it. Might not even be a fault code; this will send many a dealer into the computer says NFF mode :S but probably your best first move, unless one of the more enlightened Skoda Techs on the forum reads this and knows of a dark arts way of resetting it.
TP
Edited by The Plumber
On mine, occaisionally, the mirror does not return to the standard position but always moves down....never up
Speak for yourself, Bob!! :drunk:
This may be completely irrelevant (sorry if so) but on my Jaguar XF the position that the passenger mirror dips to is set by adjusting that mirror whilst in reverse gear - it remembers it for future. Not sure if our Yeti Elegance has the dipping mirror feature.
Seems to be ok again but has been before.Will try the Jag idea thanks Gnomeface.
Bring back a knob to twiddle with on the passenger side....... over to you Bob.
Peter
Each to their own Peter ... you fiddle with what you like!
Peter
just the same on the Yeti.
to the OP.....has somebody been playing with it? put in reverse and set up again and then see what happens.(if you haven't already done so....)
Mike
Mike
Come on - you're making this too easy! :giggle:
Got to give you something :lol:
