Help interpreting my VCDS Log
Think i have done it correctly so below i have posted the results from my scan, couple of faults found and i think they are
basically telling me that there is an issue with the electric windows and the heated Wing Mirror Which makes sense as the
wife switched it on the day we bought the car and hasn't switched it off for the last 6 years. Can anyone verify if i have missed
owt.
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Sunday,06,January,2013,15:50:40:28247
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: T*******************2 Mileage: 116890km/72632miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1Z0 907 115 A HW: 1Z0 907 115
Component: 2.0l R4/4V TFSI 0040
Revision: --H10--- Serial number: SKZ7Z0E3303066
Coding: 0203000318070160
Shop #: WSC 28061 210 92356
VCID: 33632295525B3F80ECE
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0004738
Shop #: WSC 73430 790 00000
VCID: 71EFE89D68C74D90DE2
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 H
Component: ClimatronicPQ35 084 0305
Shop #: WSC 00000 000 00000
VCID: 3B730AB57A0BF7C034E
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003845862
Coding: 018C0F030004140000110D000000000000087F075C
VCID: 2B533AF58A6B6740A4E
Subsystem 1 - Part No: 1Z2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 73430
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 R HW: 1K0 909 605 R
Component: Q4 AIRBAG VW8 018 2200
Revision: 02018000 Serial number: 0038MD02D2FZ
Coding: 0020788
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000042
Shop #: WSC 28061 210 64639
VCID: 76E5DB8101A96AA80B0
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1Z0 920 941 C
Component: KOMBIINSTRUMENT VD1 0918
Coding: 0003401
Shop #: WSC 01190 210 175197
VCID: 377B16854623D3A0D06
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105A208C61
Coding: 3D3F0348071303
VCID: 2A5D3FF185917E485F8
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 0918
Address 37: Navigation Labels: 1T0-919-887.lbl
Part No: 1Z0 919 887 B
Component: Navigation 0412
Coding: 0000002
VCID: 479B664536C3A320A06
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2346
Coding: 0000756
VCID: 36651B8141292AA8CB0
1 Fault Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
012 - Electrical Fault in Circuit
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.2 D06 1701
VCID: 34612189575538B8F54
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 01D002007F2D8505485F861004CC
VCID: 79FFD0BD30B705D0662
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000756
2 Faults Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
012 - Electrical Fault in Circuit - Intermittent
Address 56: Radio Labels: 1T0-035-095.lbl
Part No: 1T0 035 095
Component: Radio 0412
Coding: 0000402
VCID: EBD37AF5CAEB274064E
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2435
Coding: 0000144
VCID: 326D2791AD413688E78
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
1 Fault Found:
00935 - Electric Window Motor; Rear Right (V27)
End ---------------------------------------------------------------------
Thanks ill try the window trick as advised but I think the heater element will be screwed in the wing mirror anyway fromcontinual use.
Sent from my GT-P5110 using Tapatalk HD
I suspect that 00944 is from the mirror heaters being left on (they don't have a timer like the rear window demister and are not connected to that) and possibly burning out the heating element in / behind the glass.
Thanks this is my assumption too. Its no bother though as i have turned it back now to the off setting and i don't use them anyway i use the rubber blade from my scraper to wipe any ice off etc and they rarely steam up once they have had a wipe with microfibre cloth.
