Bluetooth with Stream MP3 Advice please
Hey folks.
Been searching around but can't find anything definitive.
I am taking delivery of an 07 Octavia Elegance with a Stream MP3.
I have an iO Play Bluetooth kit which has a built in amp for streaming music etc.
How do I get them to play together?
The bluetooth has a standard pass-thru type ISO connector.
I assume I would need some sort of ISO to Quadlock (?) type of thing like this?:
http://www.ebay.co.uk/itm/NEW-VOLKS-WAGEN-SEAT-SKODA-16-PIN-QUAD-LOCK-ISO-TO-CAR-/250742229193?pt=UK_Holders_Mounts&hash=item3a6166c8c9
If I'm barking up the wrong tree then tell me and point me to the right tree.
Many Thanks
Phil
If the iO Play kit is ISO, then yes - ISO>Quadlock is what you'll need.
Not familiar with that kit, but if it's standard ISO then it should work with an adaptor, like the one you've linked.
Have a look at www.octavia-vrs.com if you've not already, quite a few handy guides for the new Octy2 owner on there :) - the removal guide for the stereo will help you. Think it's under 'MFD2' but the process is the same.
Thanks Steve.
Just had a look through octavia-vrs.com. Some useful stuff.
Still not sure on puttin the iO play in. It's not ideal as it has it's own amp and isn't as good as the stereo's amp.
I might give it a go for the sake of an ISO adapter.
Did some more digging and also looks like I may have to pick up a switch live from somewhere too due to the stereo being can-bus. Just use the heated seats fuse or something like I did in the last car.
Phil
P.s. Can't frickin wait to get the car now! :giggle:
Like you say, you can always trial fit it and see how you get on. The amp in the Stream isn't all that great FYI :)
