please help my poor vrs?
my 04 mk1 vrs octavia has developed a lazy starting fault,it takes 4/5 times to start???? the car has been serviced more than required,recent full service,timing belt change after fault developed iveall the fitted new coil packs,bypassed the secondry airsystem,fitted new spark plugs,fuel filter,air filter,oil filter and new fully synthetic oil,no joy so ran a forte fuel injector cleaner through no improvements,have checked for air leaks but no obvious faults............. what next???? help???
A fault scan sounds next...?
Edited by Liverpool-Lad
Fuel pump relay sticking possibly,
I had this issue for abit last year but it seem to cure itself altho
i had messed about with the suction tank breather thing and the pipes to manifold, not sure if it had owt to do with that or not
Engine coolant temperature sensor?
+1 Othewise your just fishing in the dark,
suggest you have it done by someone local to you (brisky member) who has a full vag-com software.
The hand held devices you can get from (ie halfords) are good value for money but arnt always able to do a
complete system scan (see all the data blocks).
VCDS scan & check what the ECU is reading from the Coolant temp sensor.
Edited by pauldazzle
  • 4 weeks later...
sorry,forgot id posted this! thank you for the replies, i will update. i had a fault code reader,but to be honest the engine management light was always on due to the secondary air bypass! so when i couldnt find it i wasnt to worried ,thought i would be plugs/coils etc...ended up the wife had tidied it away :wall: as mentioned before ,i changed the plugs,coil packs,coolant temp sensor,cleaned out throttle body. so after i was reunited with the fault code reader i rescanned and found a new fault code!!! :rofl: camshaft sensor voltage to high! so went on the net for a replacement, genuine was no possible as told £160! so i looked around euro car parts were the cheapest at £60. i had bought the ignition coild from a company called car parts 4 less,and was happy with price and service the coils were in euro car parts boxes! and much cheaper, so ordered the cam sensor off car parts 4 less and for £30 delivered, i ordered sat night recieved am monday!!! and the was a genuine part!!! stamped audi in the casting etc :dance: well chuffed,fitted the part and now perfect again!
result buddy well done.....
