steering controller module
Just done a scan of the car ive bought a cruise control stalk and i have the module 1ko 953 549 bc ross techs wiki site says it cant be retrofitted but im sure ive read on here the bc modules can be retrofitted would anyone know if it is possible or if a new module is needed. Im wanting everything before i start the job so its all done at once.
Thanks That was the exact one id read me having a oo36 0070 controller it wont work typical
0036 0070 will work
1, was the wire present? (pin 13)
2, was the engine and steering controller coded?
3, Cycle ignition after coding
Ive not attempted it yet thought id check up on if i needed a new module first
you will be ok with the controller, just check for the wire
Ive never read about a wire which wire is it im to look out for
Pin 13
you have 2 sets of CAN wiring (twisted Orange) there is a pin between them that is pin 13
Most cars have the wire, some don't
